I am using a 4k vector displacement map generated from Houdini, applied to a polygon plane with ample subdivisions but am getting tesselation artifacts in the displacement. Increasing max subdivs in the Vray attributes didn’t seem to help, nor did changing the edge length (view dependent). We’re getting some strange stepping artifacts. Thoughts/ideas?
In the latest nightly/stable builds, there are extra V-Ray attributes for File nodes where you can set the interpolation to Bicubic or Biquadratic, which will solve the problem.
