Test Corona 1.4 beta + Denoiser
Hello.
This is a test of Corona 1.4beta. Made in a I7 4970 with 24 GB ram, frames in FullHD 1080. Limited to 40 passes + Denoiser, 10 minutes per frame. I hope you like it.
I think that denoiser in amazing, i hope very impatient the new release.
Question for devs: What causes that AA flickering around the notebook ? I see it in every animation.
Is it caused by insufficient AA samples ? Would it make difference to prioritize AA:GI to avoid this issue ? Or is it the GI ?
there was a bug in early versions of denoiser that caused problems with AA when adaptivity was enabled. It has been fixed since
Oh, cool. Hopefully it’s the case here :- ) Denoiser is true god-send for animation.
It would be nice if OP could re-render the animation, or a few frames.
we dont know yet which version this was..
Really great render times for the quality, very impressive.
Ondra can you tell us if we will be getting the denoiser in the C4D version soon or will that only come towards the final release? Got an animation that’s killing me at the moment!
right now A5 is finished, so it will be probably in A6
You can also try contacting us over the support portal (https://coronarenderer.freshdesk.com/support/tickets/new) and we will see if anything could be optimized.
Thanks Maru and Ondra, great info. I am going to have one final round of optimisation tries myself and then I might well take you up on your offer! I have some IES in there at the mo and lighting by HDRI which might be hindering speed.
@senapaula
what’s your denoiser settings?
