test scene
It’s for 3ds Max 2010, unfortunately. Will see if I can recreate it for 2009.
Would be good to have a test scene for Maya too…
GeForce GTX 580
Driver 263.09
512 reach at 3m 8s
- 1m 41s
- 2 460 gtx 2gb 800/2000 + 2 460 gtx 2gb 800/2000 (DR)
- 258.96 driver
mines stuck at waiting for image data? quadro 2000
thanks
GeForce GTX 580, 263.09 driver - 3m 8s
GeForce GTX 280, 260.99 driver - 14m 9s
Nice to see a benchmark scene :slight_smile:
Unfortunately my AMD 6950 is freezing… Nooooo
I have posted here also - http://www.chaosgroup.com/forums/vbulletin/showthread.php?52358-V-Ray-RT-GPU-and-ATI-cards-with-10.12-drivers/page3&highlight=opencl
GTX 460, driver 258.96 - 6m 40s
core OC’d to 800MHz - 5m 58s
my Ati radeon 5870 result
so it is 14m 17,8s
Can someone do a 800x600 render that goes to 2500 samples? I’d like to compare final image quality to iray. TIA.
here you are:
Just for fun, a node with a 3 years old 9800GTX with 512 GB RAM = 17min 43 sec XD
No one has done the test with the Quadro 4000?
I have this card, but the test scene is not ready for 3dsmax 2009.
Regards.
Thank you, bear75, I am testing with mental ray until I can get vray2.0 and that image helps.
Quadro 4000
Driver 259.81
8m 19.9s
It seems incredible this data, I thought this card would be faster.:frowning:
Thanks for the contribution Jow.
The Q4000 only has 256 cores, which puts it in the GTX 280 range of cards.
Here is probably the best videocard comparison that is constantly updated. The raw power of the vidcard should translate to V-Ray RT render strength as well, at least for NVidia cards:
http://www.videocardbenchmark.net/high_end_gpus.html
It also shows why the leader is someone who is piling up GTX460 cards. The GTX 560 will be released this month, and is supposed to be ~25% faster than the GTX 460, in the $250-$300 range
Hm, that benchmark measures video performance, which may not be exactly the same as OpenCL performance.
some results from me :wink:
Quadro 600 - 28 m 51 s
Quadro 2000 - 14 m 28 s
Quadro 4000 - 8 m 20 s
2x Quadro 4000 - 4 m 11 s
GTX 470 258.96 - 3 m 55 s
GTX 470 259,81 - 3 m 58 s
GTX 570 - 3 m 35 s
2x GTX 570 - 1 m 48 s
3x GTX 570* - 1 m 17 s
*attention.. the third slot is JUST pic-e 4x (in slot 16x) and i think this provoke this “slow” result (i think with third pci-e 16x full speed slot the result will be under 1 min.. but will check this soon)
cheers
