I want to share my corona test render. Scene has been made previously for vray and I converted with plugin from forum but after that started to fine tune , and after 3 days I am sharing final result. In attachment you can see also vray view . All C&C are welcome
Corona images really do look a lot better and natural! Only the kitchen looks a little to clean and artificial for my taste, especially the decoration like knifes and vegetables. The carpet- and sofa-material is pretty cool though, so +1 for a material-screenshot or HowTo
Thanks for comments. Sofa material is noting fency. in bump I have normal map and in difuze light grey than velvet map then dark grey. I am attaching print screen.
I also prefer corona render view. In vray i have a problem i part of image where are lot of white colors (like wall and ceiling connection) no mater how i push quality settings i am not satisfied with final result unless i use brute force. So I will continue to explore corona a lot I only miss distributed rendering. Tried to find a workflow for that but without luck.
