Any time I export a render from the VFB, the text will be cut off at the bottom. Sometimes more than this example. I can usually still see the words enough to continue, but sometimes not.
Corona v11
Nov 29 2023 19:27:40
C4D r25
Mac OS 12.5.1 Monterey
Does this also happen with hotfix 1 for V11? Have you checked the text size in the macOS system? If not can you try the following to see if it helps? Please keep us posted
System Preferences: Open “System Preferences” from the Apple menu or by searching with Spotlight.
Accessibility: In System Preferences, click on “Accessibility”.
Display: In the Accessibility menu, select “Display” from the left sidebar.
Text Size: You’ll see options for “Text Size” on the right side. Drag the slider towards the left to decrease the text size.
