Hi guys,
is it possible to use a video (mp4/mov,etc) as a texture in corona light material?
I have a screen which is split up into sections for a stage set and need a looping animation of a swirl/swish to animate across all screens.
I have connected and deleted all screens down into 1 object and then used the poly selection to select the screen elements and applied the corona light material to the selection.
I then had to change the material projection to flat and stretch along into place.
The corona light material is just png for now but it will be animated and converted into a video format.
screenshots attached.
is this the correct process to get the animation working in corona?
thanks
