Texture batchloading with preset parameters
when i go loading multiple textures i.e. using corona map select, the textures are all loaded the same with default parameters such as projection Spherical and blur 1.0.
What if i want that textures to be loaded with projection Screen and blur 0.01?
This should helpful when i need to load multiple backplates at once and i need at least those specific parameters.
So my suggestion should be to add a preset button in order to load images with preset values.
Thank you.
Raf
Hey, for the Blur changing I could reccomend this script which will do batch changing for materials/maps you need
https://www.scriptspot.com/3ds-max/scripts/batch-material-editor
