texture help
Hi friends…
just help me to find out this (stone or tile)
Thanx in advance
If you stand far enough, you could use a procedural tile map, In the advanced roullout, Tiles setup, add you tile bitmap in there, and play with Color Variance values.. It will play with each different tile color, a little or a lot depending on the values.
If you are too close, I guess you will need some geometry / manual work
maybe this tool might help you out?
it’s posted before, but long time ago and you might have missed it.
http://www.brick.com/md/index.htm
Thanx…
Hi…thablanch…I am trying that…
Hi..joost..That down loading not working…thanx…
