Texture in Corona Light...?
I was searching to place texture (soft box) in corona Light but did not found any slot…
No texture option in Corona Light…?
Thanks.
probably your best workaround is to use a 1 x 1 segment plane with a light texture applied to it. You can then add your soft box texture to the texture slot.
not clear…
“add your soft box texture to the texture slot” which texture slot, there no slot for texture in light…?
Thanks.
sorry, written in a hurry.
I meant use a 1 x 1 segment plane with a light material applied to it.
You can add a texture in the Emission channel of the light material.
Thanks.
