Cannot figure this one - I have a “striped” fabric texture created from scratch. The top and front is one group, and the end is another. Stripes in fabric shows nicly in render - but the top is all meshed up. Where did I mesh up ![]()
Hello, @kimalbech ,
Apologies for the late reply!
Does the issue occur only when using the UV randomizer? Have you used the V-Ray UV tools on that particular object?
If you have not yet resolved the issue, can you please forward that particular model by archiving it using Extensions > V-Ray > Pack Project and sending it via https://support.chaos.com/hc/en-us/requests/new to the Chaos Support team for investigation?
Kind regards,
Peter
Thanks @Peter.Chaushev - seems I have solved it. But the UV Randomizer nor V-RAy UV tools did the trick. I simply had to give up, making the surface more realistiv/uneven with Artisan tools. So “kind of solved”
Thanks again
