CAN ANYONE GIVE ME ANY TIPS ON HOW TO TEXTURE WOOD VENEERS? IM HAVING SEVRE PROBLEMS GETTING WOOD VENEERS TO LOOK CORRECT.. OR DOES ANYONE KNOW WHERE THERE IS A GOOD LIBRARY TO GET STARTED ON MAKING TILABLE WOOD TEXTURES?
tHANKS IN ADVANCE
RYAN
tHANKS IN ADVANCE
RYAN
I haven’t got an answer but rather another question.
When I use/d electricimage, www.konkeptoine.com had many proceedural textures/materials that would do the trick. eg check out their “woodlab” shader.
Does anyone know of a resource where proceedural textures/materials that have been specifically built for MAX can be found.
would love to get my hands on a rock texture or a random cloud generator that would create non repeating textures.
g ross
I prefer more to scan a real veneer. Procedural wood looks pretty bad…there is an excellent site with tileable wood textures though…
http://perso.club-internet.fr/lemog/lemog\_textures/metal\_divers.htm
They have almost hundred wooden tileables… good quality, but still from a further distance you can see certain “patern”…
I usually scan the veneer at 300 dpi (600 preferably) and manualy “glue” certain parts together on the computer.
The more detail the texture is more real final image looks…
Now I remember using Corel Texture maker that makes excelent tileable wooden textures as well as textures of a size that you define…maybe check that out as well…
Post some of your results ![]()
Regards
Martin
thanks for the tips.. i ahve a question, what do u mean by take parts of the texture and gluing them manually? i generally scan a wooden texture but find that if it has a gloss on it the scanner leaves over exposed lines on the scanned image i then take it into photoshop and make it tileable using the offset function and then blend the seem marks i just find once u place it on an object it looks very repetitive any suggestions? i will try corel texture creator we have corel here at work maybe we have that to…
thanks a million
ryan
you can also try the veneer selector, http://www.veneerselector.com/
they have a great database of high resolution images, and you don’t have to sign up, to access the site.
thanks man!!!..that site is great!!!
paul.
thanks a million thats an awesome site!!!
