Texture missing in material editor material slot
Hello guys
The material editor doesnt show the texture that is loaded on to the material in the material editor viewer. Any ideas? I had a similar problem with vray when i loaded high resolution images in the material but the reason then was i had low RAM memmory…
The bitmap is stored on Dropbox, can you check if it’s the same if you copy this bitmap to some local folder (e.g. C:) and then load it?
Also, have you tried creating a new material and then applying the bitmap? Maybe you have some special property enabled (like diffuse level 0 or the “amount” of your diffuse map set to 0?
