Make a surface, add a Vray material. In the Diffuse channel, add a bitmap. Set the multiplier to zero. Render. Here I get the expected result, no image map. Edit the material, check the settings on the map- here , I now see the multiplier at 1.175. Exit and render- the image map does show now.
