I have to request you, Would you please add nodes in textures as like fstorm, because tweaking every texture like albedo, glossiness, bump & displacement takes time. So, fstorm textures are pretty easy one texture setting we get just one attachment. i hope you guys know this already, for better experience i attache the fstorm texture screenshot.
Sorry for bad English.
Thank you
Regards
Waqar
Hi, is this something similar to what we’re already doing in the color correct map, where you can reuse settings from another map? Unfortunately I can’t see anything in the screenshots, can you reupload them in a bigger resolution?
That’s just fantastic feature.
it would be pretty awesome to have this.
- 1 for this feature
hope it visible and clear now.
as you can see the attach the fstorm albedo setting to normal map and also roughness map.
tiling texture setting everything is the same just adding one node from albedo texture.
if he changes the texture setting I mean to say like tiling, type, and rotation extra extra.
Hope you get my point.
Yes, Kind Of.
W_4_Waqar, your screenshots are almost unreadable. Are downscaling them?
LOL ![]()
Im not sure what is going on here, but It look’s similar to one of my last requests.
Would like to learn more about this
