With a mesh using a displacement map textured with a VRayTriplanar, adding a texture reference object to allow the texture to stick to the deforming mesh “breaks” the normals of the object and it does not render correctly when using displacement. It appears that once creating the texture reference object, the object reverts back to using its pre-displaced normals rather than the displaced ones.
I noticed in the release notes of 5.20.00 that work was done on the “fixing” the Triplanar with texture reference objects… well, this might have broken in the process.
We will have to revert back to an earlier build of VRay until this is fixed.
Just to be clear, it doesn’t really have anything to do with deforming meshes as such -- just adding a texture reference object with a VRayTriplanar is the problem.
It seems to work fine on my end. We’re talking about the “Reference transform” space mode and you’ve plugged the reference object’s matrix into the slot, correct? Are you rendering with CPU or GPU? Could you attach the scene and texture here so we can take a look?
This is a long shot, but do you have a lot of history on this object? I’ve seen problems with TRO’s on objects that have a lot of upstream history on them in the past. If so try cleaning up history as much as you can before creating the TRO.
I understand now. This might be a limitation by design, but we need to check. I’ve notified the developers to confirm. I’ll write back with additional information.
hi @hermit.crab 8)
we’re running into this issue as well.
would it be possible to get an update? or alternatively, is it better to email support and give them this bug number so that I can follow along that way?
thankyou!
Add a Texture Reference object at frame 1 and it should work. Texture Referencing is not available in 3ds Max, however. So we might need to think about another approach. I’ve notified @vlado about it.
