We have run into some problems with the latest versions of enscape here at the office. I think it has to do with the new support for 8k textures.
we have an extremely heavy project (an airport with enourmous detail), and have been able to work with enscape in the models before. Now though, we cant get enscape to start up, and we think this has to do with all the texture data now being too big of a mouth full. since we use hundreds of linked models it is almost impossible to resize textures en each of them (plus we would like to keep the hight quality ones for other projects).
In other projects we have no problems at all, and LOVE the support for large textures, but we miss some sort of control over it. Could it be possible to introduce some sort of texture-size slider, that lets enscape crop textures at certain resolutions, to cope with different projects… Right now we are forced to downgrade to version 2.4.1 to get the work done…
our machines are i9, RTX 2080, and 64 gb ram, so they should be punchy enough!
Sad to hear that. The easiest way to test if textures are guilty would be to temporary remove or rename directories containing those textures and check if Enscape will start, although without showing the textures in the model.
By the way, can’t get Enscape to start up means that it stays loading forever or crashes on start?
Let us know if it is possible do perform such a check in your case and if it will let Enscape start. Also please send us feedback with logs, so we can have a better look at the issue!
Hi I should have clarified that a bit more of course
I cannot unfortunately change directories like that… all textures a placed on different servers, and MANY of the textures comes from linked models…
The model starts up after around 15 minutes, first with a lot of missing textures, and then it turns into some sort of dark, pixelated image, which cannot be navigated. I can see my system memory hovers somewhere around the 50gb mark at this point…
There is no errors or crashes, but enscape (and the rest of the machine..) is not usable
in the old version, it still takes around 15 minutes for the model to start, but then it works, and we can navigate and export renders without any issues
My experience echoes Herbo’s, and as someone who also works with both very small/intricate models and VERY large models that don’t need and/or can’t handle the same level of texture detail, I would like to give a BIG up-vote to the texture-resampling slider that he suggested in his first post.
To add a suggestion to this idea - if a slider offers too much variability for troubleshooting purposes, then perhaps a “low/medium/high/ultra” option similar to the current Render Quality dialog would work instead.
With 2.7 we’ve added improved scene texture handling, that’ll on the one hand allow to work with resolutions up to 16k, however scale them down depending on their actual size in the scene. Which means very high resolutions are reserved only for large scale areas (like environments with satellite images as textures, or textures covering whole building facades). But if you’re using high resolution images from a texture library for smaller areas, Enscape will automatically scale them down as much as possible without noticeable quality loss, so no manual work required. We also do an estimate which resolutions are going to fit into your gpu memory and do a more aggressive downscaling if you’d otherwise run out of memory.
Hope that’ll be helpful for you guys, looking forward to your feedback
Thank you very much for the heads up That sounds like a great solution! exactly what I imagined. Unfortunately all versions since 2.6.0 has been extremely unstable for us, and cant handle the big airport project we are working on. i’ve tried all official releases and all 2.7 previews, and enscape regularly crashes, and we cant export images in decent resolutions. I think it might be down to the whole RTX thing not being completely optimized for work with very large scenes.
So for now, we are stuck in an old version, but hopefully we will soon be able to update
