Texture size in Material Studio?
Hi everyone.
I’ve been using the Material Studio today, and I’ve noticed that the texture size in the preview window is generally very small, which isn’t very helpful.
Does anyone know what I can do about this?
Re: Texture size in Material Studio?
Don’t think you can do anything about this. The material studio has its texture size saved in the UV size of the model. For the preview within the material studio you can decrease the U/V repeat to a value less than one, but you might want to make sure you change them back when exporting the material.
Thanks, that explains things. Might be wise, it seems, to use a separate SU instance as a “material editor”.
