Texture switch across frames?
Scenario:
1 Domelight multiple HDRs.
I was looking for a way to change textures/HDRs across frames using only 1 domelight, rather then having to control mulitple domelight + textures/HDRs.
I thought the “Loop through textures” in the MultiSubTex was the answer, but alas, that was for a completely different purpose. :slight_smile:
Is this possible?
If you name the incoming files as a sequence, and load them as such, it ought to work.
Yup, that is my current wf. :slight_smile:
