texture won't tile
Hello all… I am new to Vray and have a question. I am trying to make my own material using a bitmap file fo a peice of leather. I hit the “M” next to the diffuse color swatch
and get the dialog box, I then chose “Bitmap” and load my bitmap of the leather. When I click apply and update I get the bitmap in the window and on the object in Rhino cool, …
The problem is when I try to use UVW Transform and change to two or three repeats (I also check ‘tile’,) I can see the tiles repeat in the update window, but they won’t tile and repeat in Rhino, on the object. Very frustrated at this point, would love some help… Thanks so much… BDS
Re: texture won’t tile
If you want them to repeat in the viewport, then use the Rhino mapping tools. All the way at the bottom should have UV repeat values
