I found a weird behavior in terms of switching materials at a keyframe. Textures files are not loaded when i render the animation in VFB.
I´m working with the latest Versions of C4D R25.015 and Vray Update 1.4. Is this a known problem? Does anyone has an idea of getting it to work?
Need some help because it’s essential for continue working on my projects…
Example files:
c4d-vray-mat-color.c4d - switching materials without textures work
c4d-vray-mat-texture.c4d - first texture are loaded. 2nd and 3nd appears black
c4d-vray bitmap-mat-texture.c4d - first texture are loaded. 2nd and 3nd appears white
Thank you in advance
Christian
Color_Testfiles.zip (1.76 MB)
Hello @christian_tremmel ,
Thank you for bringing this to our attention.
Upon testing it I also managed to reproduce the issue and I reported it to our developers for fixing (bug ID: VC4D-1160). I will update this thread as soon as I have some information to share.
I noticed that this only happens with V-Ray but it doesn’t happen with V-Ray GPU. You can also keyframe and switch the texture instead of the whole material and it will render correctly as well.
Hello @aleksandar.kasabov ,
Thank you for your quick reply and open up a ticket.
I took your idea of keyframing and switching the textures by python tag and wrote a short test script.
it works in principle but for some reason sometimes skips the second texture and if all textures are rendered correctly crash Vray after rendering the last frame. I am a little frustrated. Maybe you can look over again. To set all keyframes by hand it´s in my case not possible. I have no experiance with render by GPU. I guess my settings are wrong because it´s super slow und super instable.
Thank you in advance, Christian
Texture-change_Testfile.zip (1.31 MB)
After testing over and over I got an error message. Maybe helpful:
_BugReport.txt (1.52 MB)
Are you experience the crash while rendering the c4d-vray-mat-texture-python.c4d scene? Are you using the default V-Ray GPU settings? Also, please specify what are your GPU model and GPU driver that you have installed? Thank you.
thanks for your quick reply. Yes, of course I went into this crash while rendering the c4d-vray-mat-texture-python.c4d scene.
Especially at this crash I used the default CPU settings. But the last days I switched to GPU rendering because works best in my case.
I use the default settings with Buckets - Cuda Engine. (Cryptomatte are supported)
>>>>What’s interesting, first time rendering of the scene everything work perfect, but unfortunately second time crash Vray after finishing rendering without error message.
Hardware:
AMD Ryzen Threadripper 2990WX 32-Core
Nvidia GeForce RTX 2080 Ti - Driver Version Nvidia 30.0.14.9613
Dear @christian_tremmel ,
Thank you for providing those details.
Upon testing on my end I managed to reproduce the crash and I also reported it to our developers (ID: VC4D-1171). I will let you know once I have any updates on the matter.
thank you for backing me up in this matter.
I´m looking forward to your reply.
cheers Christian
