Textures not rendering on GPU
I’m having an issue where the textures on my materials don’t render when you using the GPU but render as expected with CPU. Happens with both progressive and bucket. Anyone else having this issue?
Thanks!
Morgan
Hi, I need some more information about this case. OS, Houdini version, V-Ray versions - official or nightly? Also what’s the material, what’s the texture and where it is connected?
Hi Chakarov,
I’m using vray official release 41203 for Houdini 17.5.293 on Windows 10 (GPU: 2x RTX 2070)
The Material is a simple Vray Material with Diffuse, Roughness, and Normal textures in TGA format.
The Material is setup in the Mat context and assigned to the FBX mesh in the OBJ context.
The behavior happens in different scene files with different meshes and textures.
I’m also using some of these objects as scatter meshes on a heightfield scatter and when I do they lose their textures with both the CPU and GPU renderers, though this could be a different issue.
Happy to try a nightly build if you think that might help.
Thanks!
Morgan
Hello again @morganmcd ,I’ve tried several houdini and V-Ray versions with tga image connected to diffuse. It works normally.
Roughness is not supported on GPU. If you want to use normal bump, the imagefile with the normal map should be connected to “additional_bump” input of the BRDFBump node.
If you still have problems try to update your GPU driver, if the problem still exist I’ll need a simple scene to investigate deeper.
Ok, thanks Georgy.
Hi again, I just found that “bump_tex_color” where broken in GPU mode, but it is fixed now, the fix will be available soon in stable nightlies. This “additional_bump” works as workaround for now I guess.
Oh cool, thanks!
Hello @Ambrozie , can’t tell what is wrong with your setup, but this is an example of material with displacement and normal bump whit texture tiles.
Hi Georgy @chakarov ,
thanks for the example. For some reason, I still can’t get the fine details from the ‘‘normal’’ to show up. The material is set up in the exact same way, however, there are two differences in my scene: I am not using any displacement because I am fracturing the mesh and I am using tga instead of png texture sets.
With a Quixel Megascans texture as png works as expected.
So the tga textures seem to be the reason? There’s probably something related to the color space … or?
Thanks again, Ambrozie
Hello again, can you send me just one of your normal textures at georgy.chakarov@chaosgroup.com, so I can reproduce the problem on our side.
I’ll send them, thank you!
Hello again @Ambrozie , I just checked again and compared how VFH and V-Ray for 3dsmax behave when normal bump is used. Looks like my file, which I uploaded earlier, is also wrong. Normal map should be connected to “bump_tex_color” and the Height map to “additional_bump”. This should produce very similar result to what V-Ray in 3dsmax renders.
Here is the correct way to use normal bump.
GPU_UDIMNormals.zip (3.92 MB)
Is this background terrain from 3dsMax animated and saved in files per-frame?
Hey, Ambrozie,
I take it you’re in a hurry, and you probably don’t feel like uploading files yet again so here’s what you can do in case you’d rather not send the hip file:
0. Copy your working scene and rename the new one to debug
1. Go to one of those frames where the geometry is missing and run a single frame render to verify it doesn’t only happen when rendering a sequence (that’s very unlikely)
2. Hide all objects except the one that disappears
3. Render again to verify the problem is still present
→ now that everything else is hidden, can you please check the alpha just in case ?
4. Copy the V-Ray Renderer ROP and apply some very low-quality render settings - GI disabled, bucket sampler subdivs set to min/max 1/2, camera resolution override to 640/360, etc. Do not change any motion blur settings.
5. Give it another render - the problem should be still there
6. Disable motion blur on the camera - the problem should disappear, judging by the video above
7. Enable it again and try setting the “Num.Samples” option in the Object Properties of the Geometry node holding the disappearing geo to 2 - default is 0 which means “Use the ROP’s Geometry Samples” - IIRC those were set to 6 in your scene.
8. If that doesn’t help, try increasing the Shutter Speed on the camera to 100 or so - the scene will go dark but if the geometry shows up in the alpha, it means V-Ray is not finding the cache files to sample for motion blur
9. If you’re using alembics, try switching the Alembic SOPs Load method between “Delayed Load” and “Unpacked” - if that changes something, it’s probably a bug we need to fix
10. Lastly, the Geometry node’s Sampling → Geometry Velocity Blur method - you could try switching it back to “No velocity blur” to see if that resolves the problem
V-Ray is not doing anything fancy when generating motion blur - it just needs start and end geometry in the case when not using Velocity Blur, or an attribute when it’s being used. The parameters mentioned in points 7-10 are what affects how this happens.
I tried reproducing this here with the files you had given us a while back but no luck :frowning:
