I’m using a simple box UV mapping on tow objects. The map is matched in Rhino but not in enscape.
File here:
https://www.dropbox.com/s/jvx9bp1umsc2v45/textures%20won%27t%20align.3dm?dl=0
Enscape 2.3.3
File here:
Enscape 2.3.3
It remember me on the same problem here:
@FloatingVolume - alignment of UV’s is not something we support at present. It may be something that is fixed when McNeel roll out Rhino 7.
According to our developers, as we don’t support projections with regards to the ‘world’, the only workaround is to try to manually align the textures. This is obviously very difficult.
The developers are aware of this, however, and they further explain that the issue is either that we don’t get the right data, or we don’t interpret it correctly. They will be looking at this again though, but as also mentioned above, this might all work differently in Rhino 7, and if they fix the render queue we can make use of that.
Hi @Pete_Chamberlain ,
I’m quite confused. UV mapping in R6 seems to work well. I also see that most of the time it gets picked up by Enscape without problems.
Only in some particular cases it fails, and in the file attached you may find one of these cases.
This makes me think that it might be a bug maybe in relation to the XYZ position of the mapping widget?
Thanks for looking into this!
@FloatingVolume - the developer responsible will be evaluating this, but it will take them a whole day to do this to be able to supply a correct response.
I think they have some assigned time to take a closer look at this in the very near future.
The developers have your project file that you posted here, so they can use it to test.
Box Mapping does work, it’s just the alignment part doesn’t.
Once I know more, I will post back here, but I imagine that will be next week now.
Thanks Pete Chamberlain ,
It would be useful to know in which cases the UV position fails and if this has to do with some bug in Rhino or in Enscape.
Best!
Sidenote: at other render plugins never I had alignment issues, always I got what I see at the viewport. So, I hope it’s only a problem of data conversation. Good luck.
