Thank you Enscape!!
This week I worked on a new project with an old client. The last set of interiors I did with them I was using V-Ray for Sketchup (Version2.0), but I used Enscape this time around. Just for comparison, I tried rendering the same interior with V-Ray (as I had a similar scene already set up), and I had already forgotten how slow it feels to use CPU rendering! I also forgot how buggy things used to be, as the Irmap wouldn’t calculate correctly. Thus even 45 minutes later, I still had an incomplete rendering.
So I just want to say a huge THANK YOU!! to the Enscape team for developing an amazing product that allows me to produce nearly instantaneous high quality images from my models.
Just posted a similar shout out in another thread here… But I echo these sentiments…
We are now regularly showing RENDERED images instead of cartoons for client approvals…
Thanks @andybot for the kind words! We’re happy to see that Enscape is a valuable tool for you. Plus it’s also nice that the most important aspects of lighting etc are quite similar between the VRay Reference and Enscape :slight_smile:
One thing I’ve noticed though - which doesn’t seem to be affected by the color temperature slider - is a definite red cast in the ambient lighting of interiors. I’ve noticed it in very different conditions and I’ve not been able to figure out if there’s something I can do to get my images a bit more neutral. (I have multiple monitors, including a calibrated IPS monitor, I’ve double-checked more than once that it’s really occurring.)
Edit: It may be that environment reflections in the global illumnation add green to the indirect ambient light, which it doesn’t seem like Enscape takes into account.
However - if you look at the wall color between the two renderings - it’s the exact same RGB color that’s used. There are definitely some color adjustments going on that distort the colors
The material colors seem to be identical to me. The green shift in the Vray shift (or inverse: red shift in Enscape) comes from the scattered light from outside. VRay does this the “correct” way here. If you lower Enscape’s “ambient brightness” slider, you will get closer. We added this ambient brightness because some users said their rooms without windows and lights were too dark. That’s when we deviate a bit from reality and add some fake light, which is neutral white, hence the perceived red shift compared to the green bounce light.
To be fair, I was just looking at the latest 4.2 version of V-Ray for Sketchup, and it’s quite a robust piece of software. I really shouldn’t be comparing the 2.0 version with anything today :slight_smile:
