Hello guys! Working on project i face a question for fastest solution for my semi transparent paneled ceiling. As it is my main light source i need the most “transparent” and correct mtl for fastest rendering. Below i attach current mtl and couple screenshots. I also photographed some references at the street:). Should i decide between physical correct and rayswitched mtl or not?
The panels have some thickness as well. It nessesary to be for sufficient dispersion for nightlight. There is small LED platform behind each panel.
I use this https://forum.corona-renderer.com/ Translucent Milky Plastic topic as a starting point.
