hi
Again I made a small scene to experiment more with texturing.
Actually this is an object from my new wip scene
but I decided to make a small seperate scene of this object to practice.I tried to give dirty old look on materials except bulb. As if the bulb is newly replaced…Because I like the clean sharp reflections on glass and it adds some contrast to the old look and I like this mixture:)
All your crits are welcome!
Very nice.. did you use bump or displacement on the left thing.
Can you share some details on your dirty plastic.. its excellent.
I assume the crack is modelled in.
hi
thank you very much for your replies and nice words
the left colum is made with blend material of wood and paint with a dirt texture mask. and I used displacement. but it is very small amount of displacement. so maybe even bump can be used.
the plastic bulb head is also mix map of some colors with a dirt texture mask and on top of it another mix map of noise map again.
with little glossy reflection.
crack is a just a simple bump.I used a concrete texture map. I just cropped and played with levels and contrast and make a new texture out of it. and then mapped.
Very nice balance, pleasing to the eye, and made me squint and get closer
Bump wouldn’t work so well at a slanted angle (ie. the righthandside of the column): it works very well when it’s directly lit and possibly as face-on as it can be.
Displacement on the contrary works exceedingly well as you used it, to add more high frequency detail in those “dull” areas.
studio-dim: u r right. that is why I used displacement. because it affect geometry too. but as I said very small amount of displacement. so someone can prefer to use bump to save some render time:)
thanks again.
beautiful image and great cg skills,
it looks like i still have a lot to learn.
on a more technical note, i think there is a Health and Safety issue with that cracked casing and the rods do not extend all the way inside to connect to the mains/power/
is that noise on the right of the bulb intentional?
1- Would you be able to light this bulb up.. maybe something in a very very low Watt-age… where the coil is quite orange/red instead of a brightly lit light bulb…
2- You may need to texture the wall a bit…
3- While you’re at it and since the bulb is so close to the wall… why not make a burn mark on the wall…
