The Crown Intro
Hey guys and girls,
How would you create something like the intro of the Netflix series “the Crown”?
Particle flow? Metaballs? Phoenix?
Would love to create something similar and before I start some tests I’d like to hear your thoughts…
Pflow + Frost
Or
TP
You don’t think it can be done without having to buy another plugin? Don’t know how often I would actually use them …
I´ve tried a couple of times to do something similar to this, something I´d describe as “organic growth”, but of course depending on what you need you just need to shade it differently to get something like in the reference video.
I had some success using Pflow and Vraymetaballs, but its a bit of a hit and miss situation, if you don´t have much time to do r&d…
But I always found myself in the same situation, pondering if the few instances I need this justify something like frost…
You could create a similar (with a fair amount of artistic control) effect using growfx… If you have it. Max has a new fluid sim, but I’m not sure you can do this kind of thing with it yet?
I’m on 2015 anyway.
But I actually bought growfx a while ago and never used it. Great tip.
But would I be able to achieve a liquid-like look with it?
Do you have something to show? Would love to see your results!
Sorry, all NDA…:frowning: I was going for a more venom like thing, but basically I did some very simple particle setup with spawn by travel and meshed it with vraymetaballs.
I understand.
But it’s reassuring you had success with Metaball
I think I will try growfx and maybe it will work with Phoenix together. if not just pflow and metaball.
I’ll post here if I (ever) have something to show
I haven’t tested this, and even if it works it’d probably look bad, but here’s a crazy idea for doing this within VRay:
The volume grid can render volumes as a mesh. If you somehow obtained a .vdb file that is just a filled up square grid, you might be able to use volumetric textures as a density texture to create the shapes and animation. The VRayDistanceTex (which works with volumetrics) could be used to create the shape of the growing flow, then another object with a different VRayDistanceTex could be used to subtract from the first VRayDistanceTex, to create the growth animation.
Sounds interesting but somehow complicated Haha and I still need an object as a base or else it’s going to be a lot guess work to get it done with 3d procedural maps
