Hello, why isn’t the Filmic layer saved like all the other editing layers in the final image?
Currently, I have to copy to clipboard and then paste into Photoshop to save the image. It’s tedious, and above all, I can’t run dozens of renders in batch. Is there a way to change this? Is it my configuration?
Thank you in advance
Cyrille
If you are outputting multichanneled images (.exr, .vrimg), you need to enable the “Save VFB color corrections to RGB channel” option located in the Save V-Ray image file browse window.
Thank you for your reply.
Actually, I want to save a JPG, not an EXR (which I would then have to flatten in Photoshop). Does the Filmic layer only work for HDR images? Can’t I flatten directly to JPG or 8-bit JPG when saving?
Thanks again
It does work. Maybe your issue is related to color management?
