i intend to use this tread to learn trough a project.
I need to understand the following:
Geometry.
How does one models the liquid in the glass liquid scenario? I know i have to separate the liquid from the glass, and i have them both enclosed, normals facing outward, with a small 1 um gap between the top surfaces. Is this how to do it?
Is absorption working correctly ?
What are the correct rendering setting to be used for this scenario?
What are the correct rendering setting to be used for this scenario in order to have caustics?
i attached 3 renderings. the floor is the same glass as the other glass objects, and there’s a background in the back with a hdr emission. Maybe s just me, but i don’s think i see any caustics there. I’m rendering right now with PT+PT, but still, no caustics.
hi, #1: model it with small overlap between the water and glass. Normals orientation does not matter. #2: it should for your configuration #3 + #4: Either use PT+PT and increase the maximal ray intensity parameter to get closer to the unbiased solution, or switch to renderer: Bidir/VCM to go unbiased, although that might take more time and some features might not work
One issue i have is that, there seems to be multiple names for the same parameter.
Please tell me if maximal ray intensity is the one i have marked in the attachement. If yes, i had these parameter at 0 in my renderings.
Its test i did some time ago to answer for that questions (about geometry)
Left - water and glass are no crossing, center - crossing (0,1 mm), right - crossing (0,3 mm) and top poligon of water is chamfered (0,25mm)
Another question please. I promise, is the last one for today
I’ve read somewhere in the forum that u can get caustics only if you use hdri.
My questions is, if i take a plane, and apply a corona material with emission on, and a hdri mapped on the emission slot, is that light gonna be a hdri light?
Corona has… i really need to create some catchy name for it… what about unified lights? I mean, every physically correct light in the scene, be it environment map, enviro HDRI, sun, geometry light, CoronaLight object, … is handled exactly the same way. There are no differences between them in the results or sampling methods.
