Product rendering engineers often render close-up shots of products, and there will be faults if the image pixel number is not enough. I hope to improve this function and make it more comfortable to work
Submitted on AHA Ideas by Gai Wang (VANTAGE-I-47).
Hi Gai Wang,
Can you please explain more on what do you mean by
and there will be faults if the image pixel number is not enough?
Do you mean that you cannot produce high enough resolution image? The current resolution limit is 16384x16384px and is a limitation from the DX Raytracing API that Vantage uses.
Submitted on AHA Ideas.
Hello, ADMIN. This issue has been resolved now. It was caused by my incorrect choice of rendering denoising method. However, currently, I am mainly engaged in the product rendering industry, and the Vantage renderer is really user-friendly. But there is still a very important feature lacking at present, which is the inclusion and exclusion of lights. The reason is that when rendering metal products, the requirements for highlights and reflections are very delicate. If this problem can be solved, then the production of animations for metal products will be more convenient and perfect.
Submitted on AHA Ideas by Gai Wang.
Hello, Gai Wang. We will be adding support for inclusion and exclusion of lights in the next release which should happen around the end of this month. I will close this request as you have managed to solve it on your end.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
