The Lake House - Corona + Vantage
Hi guys!
With a big pleasure I am sharing with you a new showcase video made with Corona and Vantage.
I found some limitations on some things but the overall experience was fantastic!
Link to the 4K, 60fps version on YouTube:
Thanks for watching!
Very nice! It took 40 seconds to get into the animation, which I think many would move on, The camera is also E.T. height. other than that, beautiful work! Punch the first person who said 15 minutes of work using AI - punch them right in the nose!
Thanks for your comments!
As for the intro, yes I agree but I want a cinematographic feeling and look.
The camera was lowered on purpose, I had the same doubt but the shots are focused on the overall kitchen furniture and in that area sometimes is better to lower the visual, the perspective is nicer. But I’ll keep your consideration valuable, as I said I had the same doubt at the begining! :slight_smile:
Who said is AI??? I want to punch him right now! :smile:
Thanks again for your contribution!
I agree with Bobby, the intro is way, way too long. I really think it would benefit from a reworking which would greatly improve the overall piece :slight_smile:
The content itself is great…very engaging, with lovely shading and detail (although I’m not quite sold on the footsteps and camera motion linked to that at the outset…seems a little disjointed, sorry).
Thanks both for your comments!
Awesome quality… even with limitations. Looks amazing. Would be great to get some stats… on time per frame, how much of this was straight out of Vantage vs. Livelink? Bottlenecks you encountered, etc.
First of all thanks for your comments.
I’ll try to answer some of your questions:
- It was my first experience with Vantage and Corona Renderer and the major issues I’ve found is that still the Triplanar mapping and the UVW Randomizer don’t work! That’s a HUGE limitation!
- Another problem I’ve found was a sort of trailing effect on the objects and once changed to the Legacy Denoiser in the setup menu the defect disappeared.
- Then I’ve noticed a flickering on some wall surfaces, I had to use some high number sampling to get rid of it. I was around 1.600 samples on the sequence menu and I’ve used some other settings as well on the advanced setup menu.
- One thing that really slow me down where some black random artifacts on the images once the denoiser was kicking in!!! Solution??? Well, it seems weird but I had to turn off the Nvidia Optix Denoiser and everything then was fine. That’s weird!!! Something is not working well…
- I’ve rendered at an HD resolution and my timing was from 30sec to 40sec with an RTX 4090. After that with TOPAZ Video I’ve managed easily to produce a 4K video @ 60fps.
- All the frames were rendered by using the Livelink connection, the initial logo intro as well.
Thanks again,
Dionysios -
Outstanding. Nothing else to say.
Thanks so much! Very appreciated.
