To be honest, I’m not sure if this is an error, but it’s definitely causing me some trouble. I noticed this while testing cartoon rendering.
Use version:Chaos
Hello @qingyuan_pang Thank you for sharing! At first glance this seems normal. I would increase the resolution and give it another try. Please, let me know if this resolve the situation.
I tested increasing the resolution to no avail
Are you able to reproduce it on a simple scene as well?
Please share the scene with us so we can investigate further. You can do that here or by Submitting a Request to our system: Submit a request
Has been sent
vray toon 2.c4d (1.76 MB)
Hello @qingyuan_pang Thank you for the scene! This might be caused by an issue that’s been logged into our system [VC4D-2155] We will contact you if the matter is further developed.
Meanwhile, there are two workaround that can be done:
1. Increase the Start Width of the VrayRenderableSpline: http://ftp.chaosgroup.com/support/scenes/Cinema\_4D\_2024-01-16\_09-42-41.mp4
2. Increase the Width and Height of the Output: http://ftp.chaosgroup.com/support/scenes/Cinema\_4D\_2024-01-16\_09-45-06.mp4
