I see the poll has been reset. Could we get a post That explains some of these? I don’t have a clue what the Tiles Map is supposed to do. What would be the improvements to the CIE, would that not also mean that we improve the frame buffer. And what is meant whit new and better frame buffer (docked and floating)??¿
And I have a small request regarding the frame buffer. This is something that has been bothering me for some years now. Why can’t we compare two different images that have a different size. This is most annoying when you do an IR and than you restart the IR and it has a different resolution. Now you can’t compare them. This has been a feature in Vray for years. It’s not a deal breaker, just a bit annoying at times.
Recently I made different types of dichroic glass and played a little with the thinfilm layer in V-ray 6
and now I vote with two hands for adding a separate thin-film/coating shader that would take into account more parameters and nuances.
In general, a convenient system of layered materials with additive properties was would be very helpful.
If possible could we see a ‘Improved volumetrics’ option?
Specifically render speed and previewing in IR as well as being able to render volumetrics from within a volume.
This can be done already with the Corona Volume material, switch to Inside Volume mode and a 3D noise can be fed into any of the channels - if you mean something else, please specify
Everyone has different standards. Personally i’m too lazy to do background replacement (or in fact any post-processing) outside of Corona, so my skies are almost always empty. Procedural clouds would be great addition for me, even if not very physically accurate or photo realistic. As long as they would look pretty, i’m perfectly happy with that and from what i saw in V-Ray videos, they look pretty darn good.
I’m pretty sure Vray implementation was done in the way clouds affects the lighting. That’s what I was actually the most amazed by and I really look forward to seeing it in Corona.
It’s already on Trello board board V9 so cannot wait to see it in dailies.
I’m sure the quality will be upgraded with time (as was the case with CSky models), but if it’s like what’s available in VRay, it’ll will be yet another great tool to control the lighting and general mood. At least!
They do affect the lighting (basing this on the V-Ray ones which I played with quite a lot), so you can have them cast shadows on the ground for instance, and as the clouds animate and move, so the lighting changes and an area can move from being in shadow to being illuminated. It’s rather cool. Of course the clouds are rarely the “point” of an image and not meant to be what people are looking at, just to fill in the background, and they work great for that (without the render time hit that comes from a full volumetric solution).
