hi all… i have a problem why i use exterior rendering corona render takes a long time… to produce an image resolution of 3000 x 2500 is clean without any noise it took me 12 hours more…what’s wrong with default i… please help my ..thanks
Please give us some more information:
-what is your hardware?
-why did you change GI/AA balance to 5? Do you even know what it does?
-did you just take the scene made in Vray, used a converter and hit “render” without tuning materials manually?
this my hardware
ram 24gb
prosesor intel i7 950
-why did you change GI/AA balance to 5? Do you even know what it does? I just tried from the value of 16 to 5
The amount of GI samples per each sample antialiasing.
Higher values will increase is a sampling of Global Illumination, resulting in cleaner indirect lighting, glossy reflections, refractions and translucency. Lower values will increase is a sampling of antialiasing and therefore improve quality of fine geometry edges, Depth of Field, and Motion Blur.
Setting this value under 2 or above 64 is not recommended.
thanks maru
I would say it is more or less good times for such image res and complexity of the scene on single machine as 950.
Shoud you set GI/AA balance back to 16 and secondary solver to HDCache, render time should get significant improvement, i think.
hai crazyman thanks to help me
you mean I have to replace my engine so what I want to achieve so right
keeps the machine where appropriate do you think?
thanks crazyman
hai romullus thanks for help me
okay I will try … hopefully this helps me
thanks romullus
