Hi all
Faced with such a strange problem in the rendering process. When I run the rendering multiple frames of an animation camera, I rendered the first frame 12 times before proceeding to the next. I could not understand the cause and decided to ask you friends.
I tried to manipulate it: all the working project to import into a new scene - did not help. Tried resetting the rendering engine - has not helped. Tried to separate one room to save a new file - did not help.
Screenshot attach note underlined. Restriction on rendering I put 300 passes for checking later tried to put 3 pass - no difference was. I can not understand where do these 12 passes, in a normal situation there is always a 1/1 in the rendering process. Please help me with a problem please.
When I cancel the render, it does not stop immediately, it makes everything 12/12 passes “Parsing the scene” and then comes to a complete stop rendering.
