Hi guys,
Does anyone know why the calculation for the animations doesn’t start? This is happening to me with the latest build even in a single cube scene. While in still image mode it works
I just installed the previous build and it works while the last one does nothing, it doesn’t start. Does it only happen to me?
Hi visualtracing__
Thank you for reporting it. It is a bug(LAV-1613) and we will be looking into it ASAP. From the screenshots I think you are in a Live Link session, have created 2 cameras in Vantage, animated them, and trying to render a sequence from the animation, correct? If it is so there is a workaround for it:
Tell me if the workaround works for you.
We will let you know when we have a proper fix for it.
Alexander
hi, exactly, I was rendering to live link.
I’ll try your procedure tonight.
Thank you
Render as JPG and then merge video in other software. Render to mp4 doest work for some reason.
I remember rendering at 100% didn’t work. it had to be anything less than 100%.
I just Cancel and start again, sometimes it takes two-three tries for it to kick in but it usually does, both mp4 and rendering to images.
Was there any resolution to this, I’m having the same problem. Where can I download the previous version of vantage?
There is a “Show all versions” checkbox on the download page.
