I am not sure about the design, or the illustration for that matter, but here is the first iteration.
The architect did his own, which I thought I would share. I only share because, in our initial correspondence, he said that they do their own photorealistic renderings, however, they needed it better. The point of the story is, we need to sell with pictures and not with words. Cold calling or emailing, without proof, photorealistic means different things to different people.
I would take the runners out of there…they don’t even look like they are running, they are posing…they rendering of the building looks very good and wild grass needs some work as well
Okay, fixed the fence mapping and worked a little more on some textures. Also, I went with a little bit of a summer feel; I am not sure if that worked. I am not sure if the clients want adult trees, or younger trees; that’ll make a big difference.
Dark one seems a bit foreboding, the light fittings illuminate quite small surfaces so you’re not getting much task lighting along the ground, even for safetys sake. Are there no street lights near it?
Bad shadows, I’ll have to fix that. I was having issues with IES lights; they simply didn’t work. No matter how high I set the intensity, nothing happened.
It does look like it’s tree shadows from an IES. Try and override the shape, choose circle and give it a 4-6" diameter. See if that helps. Maybe even larger? It should help soften the shadows.
