The switch of whether to apply color mapping to Multimatte elements
While using color mapping, it is similarly applied to Multi matte elements.
Since Multi matte elements has a case where it would like to use in the intensity of 1.0, I want the switch of whether to make color mapping apply to Multi matte elements.
An ideal is that all the Render elements has a switch of whether to apply color mapping.
Alternately, make your color mapping adaptation only and keep everything linear until compositing. You shouldn’t run into this issue in that case.
--T
I understand it.
But If it can do, I would like to have carried out at a time.
Although there is this option in a part of Render Elements, is it technically difficult to add to other elements?
I misunderstood it.
Color mapping does not seem to be applied to Multi matte elements.
