Does it work in max8 ? I just installed the demo but having problems when it comes to create the leaves, either nothing happens or i get this error: Runtime Error: Mesh Operation on non-mesh Cone
Is the full version in english ?
EDIT: hmm, dont know what i was doing wrong but it seems to work now…
The “runtime error” I can read is du to script “sensitivity”.
It’s quite rare.
As I can understand on this error, it was due when the script had to collapse the branches cones.
The function that tells the script to transform the branche linked object
in a simple mesh hasn’t been taken into account.
It is quite frustrating, but as I said previusly, it’s rare.
Nevertheless, it may happen whith many leaves.
It generates a memory problem.
In your case, it 's more a question of chance.
Could you advice me again if any trouble happens again ?
In most cases, just stop it and restart it and the problem
desapears.
It happened to me to close Max once, I worked on big trees.
After Max worked like a charm.
I forgot to mention that the full version is in english, yes !
