The VFB window sometime looses its “layout”
Hello @Jorgensen_cg ,
What is the exact version of V-Ray that you have installed (go to Extensions> V-Ray> Help> About to see the version)? If you are not using the latest version, please download and install it from here and let me know if this helps with this issue.
Also, do you experience the issue with specific projects or does it happen at random? What happens if you close the VFB and then reopen it? Does that help? Thank you.
