There is an error that cannot be saved when a folder in Korean is included in the file path.
and more problem. when file name contains Korean, It occurs error too.
Plz update this
I don’t know if it’s because I’m still inexperienced,
but camera manipulation in this program is very difficult.
I’ve used sketchups, Rhinoceros, and I’ve set the camera presets to sketch up.
Although this program and sketch-up have similar ways of manipulating the camera,
but vantages move too close, too far, making it difficult to manipulate details.
I’ve changed Mouse sensitivity to 0.150 but that was not I expected.
I want to change only Orbit’s sensitivity but It changes Dolly Camera Sideways’s sensitivity too.
so It will be good to add something that can be manipulated more closely.
And when I get into first person mode, Operation using WASD and direction keys is easy,
but operation using the mouse seems very difficult. If I try to turn my head with the mouse, I have no idea what to do.
Like Overwatch or Cyberpunk 2077, the mouse is fixed in the middle, making it easy to look around something.
(1) I can confirm we have a fix for the file saving issue.
(3) Regarding first person mode - isn’t it enough to move your mouse left or right to look around? Is it a problem with the sensitivity? (Note that due to the environment variable workaround for the issue with the black cursor from the other thread, your mouse will not be locked inside the viewport while you are looking around.)
Also, there are two ways to enter first person mode. The quick way is by holding the right mouse button - this is convenient for quick small movements. If you want to walk around the scene, it may be more convenient in the permanent first person mode, which is toggled with the ` key.
Plz update this
This is fixed in the build we released yesterday - 1.4.2.
This error occurs again when using 3dsmax real-time linkage to render sequences through the “render animation with chaos vantage” function, and cannot be saved to the folder path containing Korean, Japanese, Chinese and other characters. I have to create some characters that other people can’t understand to temporarily replace it
This is really good news. Would you consider providing the function of rendering custom frames in this plug-in, such as the rendering function of 3dsmax custom partial frames? 0,50,100,135。 Then let vantage output the specified frame. Now there is only a fixed range 0-x
