hi,
i currently work from home a lot so to pick up my license at work i use teamviewer to create a vpn and i can pick up the license and work from home. However i want to bin teamviewer so my question is…
If i switch from dongle to online licensing can i use my workstation license at home while my render nodes at work are using the render node licenses. Will using the license at home some how switch off the license at work stopping the render node licenses?
thanks in advance
matt
Our V-Ray online based licensing is very flexible and allows you to use your online based licenses on any machine in the world connected to internet. The number of engaged licenses is updated instantly and if you have enough free licenses which are not engaged by the other machines, you will be able to see it and use these licenses. The need of a VPN connection will no longer be needed because the hardware dongle will no longer exist and your licenses will be tied only to your username, which you use to sign in into every workstation in order to activate the online license locally on that particular machine.
One word of advice. DON’T. Too much license dropping. Super unreliable. Sorry chaos but just hard facts. 90% uptime isn’t reliable enough. License borrowing isn’t an option either but a quick fix.
