I have a problem with thinking particles crashing 3dsmax (9 out of 10 times) when I try to render using Corona and that is with a scene as simple as emitting some tea pots from a point. I use TP6.2, 3dsmax 2016 and Corona 1.3/1.4 nightly build. I saw some sample on the forums using Corona and TP so I thought its supported. Whenever I hit render it shows “Parsing the scene” and max stops responding. Isn’t TP supported ? is there something in the setup I need to do to fix this problem?
