Third Project with Enscape
Hello !
Just got my third project done with Enscape.
I’m presenting it next week to my clients.
Like always if you guys see anything you would make different, feel free to comment :slight_smile:
Cheers
I have tryed video editing for the first time as well :
Dunno how you proceed with video links so here is a dropbox one :
Video
Looking good. Try adding a few bump maps here and there for more detail and noise, they’ll make your renderings more believable instantly!
Try adding a skirting board to the interior, a simple 15mm x 150mm in a gloss white will make a massive difference.
I’ve found that any time I have a major vertical and horizontal surface meet I need a little transition element to make it look a little less clinical.
Have a look at the last 4ish images here https://www.dma-ni.com/dma_projects/dma_view_proj/?permalink=ballyblaugh-road-5
Wow I totally forgot those skirting boards, thanks for the input !
I smiled at the juxtaposition of the flooring; tiles in the garage and concrete through the rest of the house :slight_smile:
I agree with the skirting & architrave around the doors. You might also want to add a splash-back to the kitchen and some kitchen dressing. I would also add some lighting fixtures into all the rooms.
(I’m also unsure of the internal projection of the gable section above the kitchen - if it’s a ‘feature’ then I would run a light under it to highlight it or make it bigger, if it’s a mistake I would push the gable section back so the it’s flush with the wall… It looks in a different place in the lounge and kitchen views.)
Gadget thanks,
the groove above the kitchen wall is a feature. We will place a LED roll inside and fill it with translucent colored resin. I did it once and it looked amazing.
The plan is to lower it by 10-15 cm and make it run all around the room (client whish, I would put it in the kitchen only)
A slpashback (tkanks for the word, I was missing that one :slight_smile: ) will be added in the final kitchen which will be redesigned by a woodworker.
For the flooring, I’m proud to say that it was my choice. The clients were hesitating but they seen the render… and agreed :stuck_out_tongue:
I will post some pictures with these adjustments.
Here is a glims of what colored translucent resin looks like in a piece of wood :
Thank you for your input
Latest update
-overhall ligthing
-splashback
-skirting boards
-LED band inside the wall filled with blue resin
-lamps
-bump maps here and there.
