Live Link now provides real-time feedback on a V-Ray scene created in the host application, and the new Vantage Viewport feature takes this a step further. However, using this workflow from an architect’s or designer’s perspective, I have encountered several limitations.
Taking Rhino, which I use, as an example, applications like this have inherent limitations when it comes to visualization. These include incomplete access to V-Ray features, slow handling of large numbers of mesh assets, limited material capabilities, and a lack of support for volumetric geometry. Bringing locally stored visualization assets into a Rhino model can be quite painful.
In an ideal design workflow, most deliverables come from a working model that is continually revised. I therefore want to keep that model clean and responsive, containing only essential information: the architecture itself and a clear, accurate site context. Adding visualization content makes the model heavy and slow, and also interferes with producing analytical diagrams and technical drawings. Sometimes I am even reluctant to assign PBR materials in Rhino because they significantly increase the file size, while simple color textures make it easier to export clear analytical images directly.
My current workflow is to export a
.vrscenefile, open it in Vantage, and do the heavier visualization work there: materials, scattering, and placing entourage assets. As a side note, dragging.vrsceneassets into Vantage is far more convenient than importing them into Rhino. When the design changes, I export and overwrite the.vrscenefile, then reload the scene in Vantage. This workflow is reasonably stable, but it clearly falls short of the immediacy that real-time visualization is intended to provide. -
I would therefore like more editing capabilities to be available during Live Link sessions, including material overrides, geometry placement, and scatter creation, beyond the current environment and camera adjustments. Direct feedback from a DCC scene works well for professional visualization workflows, but architects and designers have quite different needs. I suspect this is also one reason D5 has become popular so quickly among architects. Vantage’s ability to work as a standalone application should be a strength that helps compensate for the limitations of design software. I would like to see its role extend beyond providing a faster V-Ray preview window.
Scatter currently seems to lack a way to control the relative proportions of different instance objects I would appreciate having this added. There also seem to be issues with 1D scatter support, perhaps because Vantage does not recognize curves? When I create a 1D scatter in Rhino, its Target Object field is empty in Vantage, although the scatter itself still works.
Thank you!
