TIBIDABO VILLA BCN
Design & visualization - Denis Chigidin
Location - Barcelona
2020
instagram https://www.instagram.com/Chigidin
behance https://www.behance.net/Chigidin
Two things caught my eye:
  • Nice strong contrast
  • DOF
    Is the DOF rendered, or is it some post process? If it’s rendered, how many passes per frame is this, or what was the render time per frame? And did you use some denoising?
Hi
DOF is completely from corona camera. there is no simulation.
I don’t remember exactly what time it was, about 7-8 hours if I’m not mistaken. I made about 350-450 passes. the noise level was about 3 or 2.5% But i added some filmic grain to the plant view in a post-production, the original picture is much cleaner. Usually I don’t use the denoiser, I leave the quality to the maximum, but in this case I used the high-quality corona denooser with a default value.
I also noticed that here on the forum the picture increases by more than 100 percent, in the original picture is slightly smaller, I will leave a link to the originals for comparison.
I will be glad to hear advice or suggestions
Thanks you
