It would be very nice if VfSU could make use of .tiff files for textures. I got a large collection of trees mapped with .tiff images which I have to convert to a different format in order to render it. If VfSU supported the same image formats as SU it’d makes things allot easier.
Re: TIFF support
I’m not sure if we are going to add tiffs because the come in a lot of “flavors”. If we did it probably won’t get to you for a little while, so you may just consider batch saving them all as jpgs through photoshop. If you go to File> Scripts> Image Processor, that should allow you to process the images you need. HTH
Re: TIFF support
I don’t suppose you would what flavours SU supports and match that?
Mass converting the files are no prob, what takes time is reassigning the materials of existing models.
Re: TIFF support
Supporting the Alpha channel from pngs is something that we intend on adding.
