Hi All,
What’s the best way to make tile grout non reflective with a glossy tile? I’ve tried using a B&W image in the texture slot for reflection glossiness, but then lose control over the amount of reflection
Hi All,
Hello, @nick_chun ,
You can try setting a black and white texture in the Reflection Color slot instead (the tile grout needs to be black) and leave the Reflection Glossiness to a value that works for you.
Let me know if this helps.
Kind regards,
Iva
Thank you Iva,
That works well with the right images for the maps. It also helps me understand the process better.
Thanks again
Nick
