Hi there,
Can anybody tell me how/where do I increase the tile size of a material in the the VRAY material editor?
Thanx
Take care all…
Hi there,
Thanx
Take care all…
Use sketchup to resize materials
if you don’t want to use sketchup to modify the repeat or rotation of your texture, you can also modify these values in our texture editor. Using SketchUp’s built in tools is generally easier to work with though, because then you will see the result in the viewport. Adjusting values in our texture editor does not reflect in the viewport.
Can you tell me how exactly do I go about it? Where in the Texture Editor do I change it?
