Tiles with rounded corners?
Using Textures, is there a way to add a slight radius to each corner of each tile, instead of it being so rectilinear?
Hey @jeremy_levitt ,
This is not something possible to achieve with Tiles texture, and we’ve logged a request (internal ID - VRW-3357) so our developers can have a look and see if this is something possible to implement. Will let you know whenever we get an update on the matter.
There is a possibility to use the Bulge texture as a workaround, although you will not have much control over the corner radius. We’ve prepared an example for you to check, however, we’ll see if any improvements could be made in this regard.
Bulge.zip (117 KB)
