Hi all,
When I use one of the Cosmos materials that combines displacement with a normal map in the bump channel, I get some strange tiling artifacts on the surface. Any ideas what might be causing this?
Kind regards
The normal map is using wrong settings. This results in the “flat blue” not being the “planar normal”, but instead being slightly tilted. The solution is to inspect the normal map and make sure its settings are 100% correct - I would personally check all combinations of flip/swap settings and different gamma/color space modes.
Is there’s UVW randomizer involved in the material? If that’s the case, make sure that it sits in the correct place, i.e. the normal texture cannot be randomized before it gets passed to the Corona normal shader, otherwise you will get incorrect normals result that looks similar to what’s visible in your screen.
Sorry, I thought Mapping Randomizer was mentioned in this thread.
I assumed that it was used.
In addition to my and Romullus’s previous messages, please also check out https://support.chaos.com/hc/en-us/articles/13800753963537
Please also name the exact material used so we can check it. There was a similar case recently.
Hi there,
I used the material Gravel_D01_80cm. Since the camera was quite close to the surface, I needed to add some displacement, so I added a displacement texture to the material.
That is when the problem appeared. The normal map strength in the original material is set to 350%. When I reduced it to around 80% or less, the tiling artifacts became much less noticeable.
Could you please send me a link where I can upload the scene?
Thank you
You can attach it to your reply in this thread, if it is of reasonable size (save selected of the surface then archiving the scene should be less than 100mb), or send it via ticket here:
https://support.chaos.com/hc/en-us/requests/new
I used the ticket because I could upload only a file of the size less than 10 Mb.
